주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
This 'SHIELD Pro' Android TV console by Nvidia is a slightly enhanced version to the 'SHIELD' console released for sale on May 28th, 2015. It contains mostly the same internal hardwares as the original 'SHIELD' console with a much higher storage capacity of 500GB as compared to the 16GB of the standard 'SHIELD' device. The model number for the device is P2571.
Nvidia shield will not power on? No green light or anything :(
I powered my Nvidia Shield off at night and tried to turn it back on in the morning and I cant even get the green light on. :( I got a replacement power cord but still no luck :(
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 12개
any luck? i have same problem too...
I have the same problem and its 4 months out of warranty. Thinking that's why they came out with a 2017 model that the same insides. There's a problem they know about it and fixed it on the new ones. ( i hope) and everyone with the old ones too bad. Now since its a old product they don't have to do recalls.
i have same problem too. ( ihave nvdia 2017)
I have same problem with nvidia shield Pro I get greenlight but will not stay on when connecting power cord or touching the power on off on top of shield with remote it does the same green light will not stay
on
*******Disclaimer**********
i do not know the Nvidia shield.
You said you have a new power cord....
how about the power supply? is it internal? or are you referring the power cord as the power supply?
댓글 7개 더보기
댓글 달기
답변 7개
가장 유용한 답변
The issue is with the cheap capacitors installed in the 2017 model. The capacitors overheat and then crack, the component costs about 50p to replace, but Nvidia don't want to know!. You would need to take your Shield to a professional repair centre. It can be fixed!
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
which cap? Do you have the location information and part number?
I would also like to know which caps, I cannot find anything on them
댓글 달기
mi nvidia shield pro 500gb de 2015 se enciende luz verde pero no detecta el hdmi no se que hacer ya que no veo imagen ninguna para poder seguir los pasos de reparacion alguien me puede ayudar a reparar de alguna manera mi nvidia para poder recibir imajen el la tv y poder restaurarla?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
hola buenas, mi nvidia shield tv de 500gb si se enciende la luz verde pero no recibo señal en la tv e probado con otros cables y tv y sigue igual no se. alguien me podria ayudar a repararla para recibir ijagen en el hdmi y poder restaurarla, e probado todos los metodos y no e podido si alguien me puede echar un cable se lo agradeceria un saludo y gracias
I have same problem, I've tried a hardware reset, but nothing happens. only get the green light, but there's no response from the board it seems.
댓글 달기
Um,I don't have the exact issue but the thing is I was playing on a game right,After I was trying to get something next to it I knocked it off and my dumbass took off the power supply(I had no intention to do it so um I wasn't thinking straight)and now it can't turn on,There's no green light.Any idea how I should fix this???
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
댓글 달기
Same problem I bought a new power cord no luck it won’t power up
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thank you very much for your answer, I was thinking to sell it on eBay like it is but now I think I will keep it, thank you !
이 답변이 도움이 되었나요?
점수 0
댓글 달기
On mine had kinda the same issue didn't work for weeks so 1 day just cleaned the metal prongs inside and out for cable bit even bite it a little also make sure plugs gold connectors when u slide it off touch too
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a 2017 model and same thing for me: no green led anymore.. So I opened the shield and desoldered nearly 20 caps (i don't have thermal camera for voltage injection method and heat detection..) before I found the one that was shorted! I replaced it and voila!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rachel Almazan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 20
지난 30일: 55
전체 시간: 9,646
