주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
5198 질문 전체 보기
Camera not working after screen replacement
Just after replacing the screen on my iPhone 6 I noticed how both the flash and video camera work perfectly, even the panoramic view has no problem but the camera does not work. The camera app doesn't show the screen because its all blurry. What did I do wrong and how can I fix it?.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 1개
You may have accidentally disconnected the back camera while replacing your screen. A more common issue is, your front camera flex could've been damaged in the repair process. If the front camera goes out, it could cause issues with the back camera.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
How could I fix this issue?, im not really sure about that because I can still record but no pictures.
i'm also going through a similar issue, my iphone seems to be seriously shoerted or something, It's draining up the battery and for some reason both the cameras and flash aren't working.
의견 추가하세요
귀하의 답변을 추가하십시오
Marcelo Marquez 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,440
