주요 콘텐츠로 건너뛰기
AirPort Extreme 베이스 스테이션과 함께 출시된 이 하드 드라이브 장착형 제품은 Time Capsule NAS에 802.11ac 속도를 제공합니다.
56 질문 전체 보기
Time Capsule reset not working
Here is the challenge:
Airport Utility cannot see the base station from any computer, phone nor iPad. I suspect wireless connectivity is not working either (hard to tell because I have several base stations creating my network). To make matters more confusing, I have a computer plugged into the TC. That computer cannot see the TC in Airport Utility, but uses the TC for a wired internet connection that continues to work. I have powered the TC off and back on again, done a soft and a hard reset all to no avail. All LEDs remain green, but I still cannot backup, still cannot use the drive and still cannot see the TC in Airport Utility. What should I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I suggest that you start by performing a "factory default" reset on the problematic TC.
You may have to do this a few times to get it to "stick." Once done successfully, the TC will be back to its "out-of-the-box" configuration as a wireless Internet router broadcasting an unsecured Wi-Fi network with a network name of something like: Apple Network NNNNNN
A Mac should now "see" the TC in the OS X/macOS Wi-Fi icon drop-down menu under new base station. Select it and the AirPort Utility should fire up so that you can make any necessary changes to meet your networking goals with the base station.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
stephen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,941
