주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
893 질문 전체 보기
Cameras & Flashlight Stopped Working After Camera Replacement
Hey guys,
I bought a replacement rear facing camera for my iPhone 6S Plus from iFixIT, (iPhone 6 Plus Rear Camera) and when I reasselbmed, neither camera works and the flashlight no longer works. I tried it with FaceTime, etc, all I get is the black screen when I open the camera app. I have restarted, closed the app, even did a full restore and setup as a new phone.
When I went to switch out the camera to my old camera (the camera lens cracked) everythign worked again. Thoughts?
iPhone 6 Plus Rear Camera 이미지
상품
$21.99
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
선택된 해법
It sounds like you either incorrectly connected the replacement camera or it is defective. Even when ordering from a solid vendor like iFixit, you can still get the occasional dud. Small parts are notorious for poor quality. I can't speak for iFixit but I doubt they test every single part they get from their suppliers.
So try to re-install the replacement camera one last time, then go back to the old, cracked one. If it is clear that the replacement camera does not work, call iFixit and have it replaced under warranty.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thank you Minho, I will reach out.
@thisistoto, if you found my answer helpful, please select "Was this answer helpful? - YES" and/or if my answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
의견 추가하세요
귀하의 답변을 추가하십시오
Jonathan Toto 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 114
