주요 콘텐츠로 건너뛰기
Nikon D600 24.3 MP CMOS FX-Format Digital SLR Camera
16 질문 전체 보기
Camera won't turn on (more details, not the same guy as the previous)
As in the other question title like this, I can seemingly charge the battery through the USB on the side of the camera and it will light green on the on/off button, but I cannot turn it on.
When I connect the USB to my computer, the camera gets registered for a split second, and the cuts off imedietely. Plugged in here, it lights green on the on/off button, and quiclky by the flash icon right next next to the display button.
When I plug it into the PC, the on/off button lights green, and when it does that, I can press and hold it, and it turns off, and if I press the button within a few seconds it lights back up, connects, and disconnects. This leads me to believe that the button works, or that it is atleast not completely dead.
Thank you in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
the USB ports on Nikon DSLRs are for data transfer only, you can not charge the battery through the USB port, you'll need to use the MH-25 mains charger to charge Nikon EN-EL15 battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
simon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 233
