주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
iPhone 7 No Vibration after water damaged
Dear Everyone,
My phone (iPhone7) got water damaged.
Everything working wells except the vibration, I guess is the Taptic Engine thing.
Im find a weird situation where, under the settings (Sound & Haptics) if I turn on "Vibrate on Ring" and select the ringtones, all the ringtones having the same Ringtones Sound which is (Opening (default) ) sound.
If I turn of the "Vibration on Ring", I'm able to play ringtones when I choose other selection example (Apex, Beacon and etc..)
My question is if I replace Taptic Engine does it resolved my issue?
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
I believe that the taptic engine fix is a good idea. Happy fixing!
Youre luckier than me my brand new iPhone 7 fell into water just for 20 second and the Taptic Engine stop working and my lcd got this weird water damaged
Taptic engine or Home button u10 ic or Change backlight or U3602 ic replacement.
I am broke in the same place
댓글 달기
답변 15개
선택된 해법
Ifixit has a guide here to fix the feedback motor. Try switching the switch on the side. If you can feel vibrations after that, there is no need to replace the taptic motor. Otherwise, I recommend replacing the taptic engine. You do know that the iphone 7 is waterproof, rite? How did it get water damaged?
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Switching side no vibration. I'm not sure why does it get water damaged, I'm just wash it will low pressure for few seconds. Brought to apple service center and they claim that it is water damaged and warranty does not covered
Well, did you take it underwater for more than thirty minutes and farther than 3 feet below the surface? If so those guys at the apple store are correct. If you did not do that, than your under warranty. Go to the apple support website and tell them about your problem, but don't tell them what the guys said about water damage.
댓글 달기
I solved this with a hard reset, on/off button simultanious with the volume down button, wait untill it reboots. The phone is water proof BUT when it is exposed to water you have to wait 5 hours to charge it.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
what is the source for 5 hours? Is that an Apple recommendationn?
Yes, it’s on there website. It’s actually a way to be sure no water is left in the charge port...
Is it necessary to switch off the phone for 5 hours before charging? Or let it be?
댓글 달기
Soaked my iphone 7 plus under the faucet for about a minute or 2. Vibration and haptic feedback stopped working after that. Ive read somewhere of the same case wherein the vibration/haptic worked again after 12 hours. In my case i just waited for around 5 hours before it came back. Hope it works for you.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
Funny, i went to the beach yesterday and dropped it. I thought well it has some water resistance so when i got home i dunked trying to get the sand out of the power connector and speakers. Thought i was good till the taptic feedback stop working. Turned it off went to bed. This morning didn't work, freaked out and started look on ifixit. Read your comment and was oh i'll just wait a bit. Checked my phone right now and it works again like normal. lol Thanks
You’re super lucky I waited for 2 days nothing happened and my lcd got strange water damaged
OMGEEEEEEEEE! It worked for me!! Thank you so much!
I went to the beach with my iPhone 7 Plus believing it’s a water resistance and when I get home I see signs of water on the screen and the haptic and vibration stopped working 10 months ago
댓글 달기
Hard reset worked for me. Hold the down volumn and power button.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
I tried three times with Hard Reset, and it worked.
Thanks for helping guys!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Yes! Me too! It worked on me!
댓글 달기
I also had the same issue. I washed my iphone 7 under water and after about half an hour the haptic engine stopped working. Now it works again. I remember i tried keeping the back of my phone close to my ear and i heard slight sparks. I left my phone shut down for approximately 5 hours. Then it worked for a while and stopped working again. After that i left it turned off overnight and then it started working and still is. I guess the trick is to make sure the water evaporates before it gets to do any permanent water damage.
I hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same problem the home button in my iphone 7 is not working and one of 2 speakers not working because I washed my phone and tried it for a quarter of an hour and I was playing music and then I dried my phone out of the water and then put it on the charger for 10 minutes and after 10 minutes I looked at my iphone written "The home button May Need Service" So Is the solution is turn off the phone for 12 hours or 5 hours ? please I'm in Saudi arabia we don't have Apple store help me :(
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hi Waleed, im facing the same problem..were you able to fix the problem?
I update my iPhone 7 Plus from iOS 11 to iOS 12 Finished update my vibrate not working . . I try hard reset also not working
It will working if I turn of the phone and put it in freezer for 2 minutes. And turn on the phone it will working .... if the phone watch 10 minute YouTube / phone call the vibrates will stop again (It will work again if turn of and put it in freezer(cooling down) What parts I have to replace Hellllllpppp. Thank you
댓글 달기
Anyone knows how to fix this without taking it to the Apple Store? I'm abroad right now and there isn't an Apple Store in this island!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i am just after repairing a water damage iphone 7 after swimming pool incident . From what i seen the entry point appears to be via face on, bottom left mesh of your phone. i detached the haptic connector and seen slight corrosion. i cleaned with 99% isopropyl, back together and working perfect now .
also someone had mentioned loud speaker (bottom right of phone) not working correctly after water . try this . Download an app called Sonic (app is orange with a black wavy line through it ) set to about 450hz for 5 minutes say, then that will physically push moisture out of the mesh.
try it even now and you will feel air com out if held to your lips
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello everyone,
So I got my screen replaced after I broke it and was recently in the bathroom and somehow the iphone 7 came in contact with the water for like 2 seconds. I quickly threw it off on the bed. After I came back from the shower, I saw that the phone was automatically rebooting. I thought it's updating the firmware but later "Your home button needs to repair" popup came up with assistive touch. The Touch ID was working fine & the the silent/loud switch was giving vibrations when toggled.
I put the phone in rice bowl ( I know it doesn't work but maybe placebo effect :P) and kept it there overnight. Morning i took it out, blew hair dryer for like 2 mins and started the phone. Works without any issue. :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I tried the rice method and it intermittently solved the problem then it stop vibrating again. I solved the problem permanently by vacuuming the bottom section of my iPhone 7 Plus. My guess is I managed to vacuum all the water out of the ports.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I dropped my iPhone 7 into water while it was ringing so it drained. I disassembled it hence dried all the water out and i booted it again but Upto now my phone vibration doesn’t work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have same issue, also water damage, but the phone is heating on bottom side (around TAPTIC ENGINE)
is it possible that there is something else broken or only replacing taptic engine will fix all this?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I got mine replaced by Apple. You could bring it to Apple Store and let them diagnose. As i know for haptic engine issue, there is no part, it's one to one exchange.
이 답변이 도움이 되었나요?
점수 -1
댓글 1개:
Here at ifixit we exercise the right for self repair.
댓글 달기
You should go to Apple store and ask them to diagnose. Then they should replace it for a new one and you probably would have to pay a part. As far as i know there is no taptic engine part available to replace. I recently had the same problem in my country and I had to pay something like 380USD, but I got a new 7+ 128Gb.
PD: On the diagnose they told me the water pass trough the home button.
이 답변이 도움이 되었나요?
점수 -1
댓글 2개:
You can buy the part on eBay for 20 bucks paying $380 isn't the answer
You have the same answer as the other guy.
댓글 달기
답변을 추가하세요
jackchew21 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 32
전체 시간: 59,076
