주요 콘텐츠로 건너뛰기
자동차 제조회사 Jeep/지프의 스포츠 유틸리티 차량 수리 안내서 및 지원.
392 질문 전체 보기
Jeep doesn't want to start, need help!
I have a '92 Wrangler YJ, 2.5l 4cyl.. I just bought a new starter recently because of the same thing.. It left me stranded at the park but all of my lights and everything else worked. I just had oil in my starter but I fixed the leak. This time, it blew a 50 amp alt pwr.2 fuse and also the 10amp I.O.D fuse as well.. I replaced them, and now nothing comes on, not my lights or even my guages. I've tested my battery and its not dead. I tried crossing the poles on the starter to try to start it, it acted like it wanted to crank but it started making a sound like boiling water makes so I unhooked it from fear it'd catch fire. Any suggestions? I need help as soon as possible. Could it be my starter, solenoid, relays? Anything. PLEASE HELP!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Disconnect the starter then see if your lights work or if theres a short in the starter . If it got a lot of oil in it its probably shorting in the starter. You can test the starter off the jeep with booster cables .This is done by hooking a ground to the case and hitting the pole on the starter with the power. Odds are you will need to replace it again . Hope this helps
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Andy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 128
