메인 콘텐츠로 스킵하기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3347 질문 전체 보기
Why there are stains on my screen?
Hello! Today i tried to deconnect my iPhone5 display , because i welcome some touch problems. After i deconnect it , i put it back and after i power on my phone that was a little mark on it. After that i deconnect it and there was a space between the digitizer and the LCD . I tried to blow between them because i was thinking in my deconnect process some dust entered there. After that on my screen appears some white stain like a finger touch . What is the problem could i need to change the display or is the digitizer?
P.S: Sorry for my bad Enghlish.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
On the iPhone 5, the LCD and Digitizer are fused together (at least, they're supposed to be). You will need to replace the entire screen assembly, preferably from a good supplier. You can order it from iFixit if you want.
Follow this guide to replace it.
iPhone 5 Screen 이미지
상품
iPhone 5 Screen
$49.99
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Is that the only possibility?
의 답변
Your screen has separated. If you split it open completely to clean it you will likely just damage it some more. You want to avoid any liquids getting in too. So you either keep it the way t is or replace the screen.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Oncescu Razvan 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 597
