Seeking info to replace cord for very old dremel-like craftsman tool
The cord on my ancient craftsman dremel-like tool is cracked and disintegrating, and needs to be replaced. The model number is hidden under a part and can't be seen w/out disassembling.
Does it need a special cord or can I use lamp cord? It shaped like a gun with a handle coming down from the main part. The cord on it now is round and thick.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Also - is it safe to use it like this?
의 답변
Please post a couple of pictures of what you are working with so we have some idea.
의 답변
Here's a couple of pics. Does anyone have an idea how old this is?
의 답변
pics below.
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
Most hardware stores have spools of electrical cable. Remove the cord from the tool and bring it to your favorite Hardware store. They will help you build a cord for your tool with the proper ends and gauge. Make sure its grounded and the gauge wire is the same or heavier than the original. I love being able to fix these old tools, they don't make them like they used to.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
가장 유용한 답변
I agree with @mayer, a picture would be helpful.
That said, if your electrical cord is "disintegrating", then it is absolutely not safe to use. As far as replacing it, you need to replace it with a cord that has the same gauge of wire to insure that it can handle the current required by your drill. A competent clerk at a hardware store should be able to show you similar gauge wired you need.
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
trying again.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
glass lady 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 53
