주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Replaced full screen assembly now Touch-ID doesn't work
Recently replaced my screen along with the LCD screen, I took the original home-button and the backplate with the home-button cable and installed it. Went into settings and tried to set a Touch-ID and the error message "Failed Unable to complete Touch ID setup. Please go back and try again." I've tried all software related fixes that I could find on the webs but nothing worked. Please help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
This seems to be a hardware issue, not a software issue. Did you make sure the connections were tight?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Are You working on a 6 or 6S? The 6 has the home button ribbon attached to the backplate which can easily get damaged. That can be replaced. If you damaged the home button than you are out of luck. If it's a 6S the home button ribbon is built into the screen and if that's damaged than you need another screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I took the original thingy that the home button cable was attached to, homebutton is also original and sits in my phone still.
댓글 달기
귀하의 답변을 추가하세요
bamsemcpro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 142
