주요 콘텐츠로 건너뛰기
Repair and disassembly guides for GE Microwave ovens.
339 질문 전체 보기
Digital disply is off
GE profile microwave, PEM31DM4ww, 4 years old, digital display is off, unit not working. After unplugging and replugging it started working, after a few times of unplugging and replugging it stopped working.
What to do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
@rekeren I wonder if this "few times of unplugging and replugging" finally led to the failure of the part. Most likely an IC that controls the display. I think at this point the only thing you could consider is replacing the control panel. The cost for that maybe more than a new microwave, but you can always try to find a "recertified" panel
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Unit is still working, after a number of unplugging and re plugging to 110vac.
댓글 달기
@rekeren Sounds like a connection issue. After unplugging from wall outlet open up the touch panel and digital display and locate any connection points to the display, unplug them and dip a cue tip or micro fiber cloth in rubbing alcohol and wipe off copper connectors as best as you can. Make sure the contacts are air dried before you plug them back in and that should resolve the issue. If not check for damage to connectors in the touch panel. It could be from age (dust/humidity over time) or power surge. Hope this helps!
- Jacob
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
eitan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 37
전체 시간: 2,941
