MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
522 질문 전체 보기
MacBook Pro keyboard keeps typing multiple letters at once
So out of nowhere my keyboard seems to be malfunctioning (No liquid spills, overheating, and it hasn't been dropped). When I type certain letters, I'll get a combination of surrounding letters too. For instance, if I type the letter A, I'll get as instead, the letter January gives me jkl, etc. To even log in I had to use an external keyboard because upon restarting it just types \\\\\\\\\ continuously. If I press the caps lock key, it cannot be turned off again.
It's a MacBook Pro Retina 13-inch early 2015, and I got it about two months ago. I do have apple care, but if it can be fixed by changing a setting or something I'd rather save the hassle and do it myself.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Will either be an issue with the keyboard or keyboard connector, caused by a small amount of liquid.
Check the keyboard connector on the logic board for liquid damage. If there is none, it will be a keyboard issue. The keyboards are riveted in on this model and you have to remove the battery as well, so if you haven't carried out repairs before, send it somewhere.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Even condensation in humid environments could be the cause.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Lauren Darby 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 41
지난 30일: 164
전체 시간: 4,991
