Why is home button not working now, on ipad mini 4 wifi?
The initial repair was a broken headphone jack. I tried several ways to remove the broken off jack. I ordered a replacement and used that to perform the repair.
In the teardown I mistakenly tried to separate the glass from the digitizer. That resulted in the screen malfunctioning. I ordered a replacement on my dime. I have installed that without any trouble. The home button is not responding after the repair. I was very careful removing it and do not believe it to be torn anywhere. That said there is no response from the button at this point.
Any help would be appreciated.
좋은 질문 입니까?
댓글 1개
In response to kmcrawford111:I believe the white ring you refer to is dried super glue. If I get a chance to take it apart again I will clean the old adhesive and put new in there. Thanks for the suggestion. I did not put new adhesive or super glue on before reassembling. I was very careful taking it apart and felt confident that I could reuse the adhesive that was there (apparently I was incorrect). Thanks for the response.
jimesta 의
