주요 콘텐츠로 건너뛰기
Headphone is working on one side only
I've just changed the headphone jack, but nothing has changed.
I've already tried several headphones, nothing happened. Any idea of what should i do ?
I've researched some places, there might be a channel problem, but how to solve ?
Thanks a lot !
Rgds
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Thanks for the answers. I'll try the dock connection and will let you know.
rgds
I did test it on da dock n it seems to be a problem with da headphone jack. thanx a lots ppl i appreciate it.
Vinci, don't forget to accept the answer that you found most helpful.
댓글 달기
답변 5개
선택된 해법
Well there are two different ways to fix this. One is a "ghetto"way and another is a replacement. First way, the "ghetto" way is to slightly pull up your headphone out of the socket while turning it counter-clock wise to receive sound in both sides of your heads phones. The second was is to buy a new headphone jack audio jack ribbon for your ipod. It cost about only 5-6 bucks on ebay. Bewarned, it also changes your hold switch because they are connected. It's a very easy repair. it should not take you more than 10 minutes.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi,
if you use the dock connector for play back and there is also only one side working it seems to be a problem with the logic board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi,
as he already changed the headphone jack
"I've just changed the headphone jack, but nothing has changed."
that doesn't seem to be the problem, so it might be the logic board. And to test this he should try to play back via the dock connector........
해당 답변은 도움이 되었습니까?
점수 1
댓글:
This should be a comment on the answer you are referring to.
댓글 달기
"if you use the dock connector for play back and there is also only one side working it seems to be a problem with te logic board." This is true, but he is talking about the headphones. This is dealing mainly with the audio/hold headphone jack. What your saying is a completely different story. I do understand where your are coming from.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Instead of quotting another answer, you can comment on it, which makes everything easier to read, FYI.
댓글 달기
hi!! I have the same problem, I can only hear on one side of the headphone. in fact, i have two headphones, and the problem exists in both of them. so, in my opinion, there's a technical problem with 5th generation ipods.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Hi Lena,
i`ve tested my ipod at a dock system and it worked, clear stereo sound, both sides playing. this means that the problem was not with the logic board. I`ve bought another headphone jack, changed again, and everything is fine now.
You can find this part at the link posted above, on Dec 28, 2009, by Nat Welch.
good luck !
thank you very much!! i'll try it:)
댓글 달기
귀하의 답변을 추가하세요
Vinci Araujo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 40
전체 시간: 14,507
