주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2696 질문 전체 보기
Won't turn on after screen replacement
Ok I replaced my Iphone 6s screen today. At first before I took off the old screen the worked despite the digitizer and lcd being broken. So I took off the old screen and put the home button and everything back in the correct way. The new screen won't show anything. When I plug it into my macbook it asks for permission and to confirm it on the screen. Does that mean the phone is still on and I just can't see anything on the screen? I've tried the holding down the power button to reset it that didn't do anything. I've tried holding down power and home to no avail. I've tried shining a light at it to see if the backlight was messed up the screen doesn't show anything. Any other suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 1개
iphone 6s spacegray128gb won't turn on and charger for me
댓글 달기
답변 6개
선택된 해법
If you cant see anything on the screen, even with the old screen on youve either blown a ferrite or the lcd driver chip on the motherboard, I fix these all the time from people that have done their own screen replacements and not disconnected the battery first.
해당 답변은 도움이 되었습니까?
점수 7
댓글 12개:
The old screen still lights up just it's cracked LCD and digitizer. So I'm beginning to think it's the new screen that is bad. I will replace it and post back to let y'all know if it was or not.
If the new screen isnt working, just by deduction you have a bad screen if the old screen still works. First rule of problem solving, try it with a known working part, if the part works, the problem is the other part.
how do you fix it?
well, the screen works perfectly on another 6s.. but it won't work on the one i'm doing the replacement on..
Have you checked that the phone is turned on successfully by plugging it into a computer and checking iTunes to see if it detects it as 'iPhone locked with passcode' / 'Trust this device to computer'?
댓글 7개 더보기
댓글 달기
가장 유용한 답변
I had the same problem and was about to scrap the replacement screen but first I tried disconnecting the battery connection again and holding the power button down for twenty second. When I reattached the battery and held down the power button it fired right up. Funny thing was that the old screen would work without the whole process of disconnecting the battery when I reconnected it in an effort to see if the new screen was faulty. This may just be something to do with the seven plus since this has never happened on other models.
해당 답변은 도움이 되었습니까?
점수 20
댓글 18개:
you are the man. I was down to getting ready to scrap the screen as well
tried what you said and boom it worked
Man thanks! My phone now working! I was scared that my LCD connector in broken.
It would have been wonderful had the directions that came with the replacement screen mentioned to disconnect the battery before starting the removal of the old screen. This method worked perfectly for me! Thank you for the solution.
You're a champ mate. Thought I &&^&@@ my phone but this 'fixed' it right away.
!&&* yes you saved me!!!
댓글 13개 더보기
댓글 달기
This happens sometimes, with newer iPhones. Disconnect everything, including the battery. Discharge the phone by holding down the power button, after you've done this. Then reconnect everything and power it back on. Hopefully you haven't damaged anything during the initial repair
해당 답변은 도움이 되었습니까?
점수 6
댓글 7개:
Tried that nothing on the screen iTunes recognizes it when hooked up just nothing from screen. Old LCD lights up even though cracked. So any chance it's just this screen or what? When I call it it doesn't ring or anything but iTunes still detects it.
When iTunes recognises it does it say it is in recovery mode? If yes then sounds like iOS 10 decided to brick itself like usual and requires either an update or restore to fix.
A black screen lit up may indicate the phone is stuck in DFU recovery mode.
Yes it detected recovery mode when I put it into recovery. I can't tell if it's in dfu mode as I can't see anything on the screen it's like there's no light on the screen at all. So I would have to update it to see if that corrects the problem?
Okay, it's 99% likely a defective screen.
Yep. Get a new screen
댓글 2개 더보기
댓글 달기
Solved: as previous posters have mentioned, if the screen will not turn on after servicing the phone, disconnect the battery connector if you haven’t already. While still off, hold the power button down for 10-20 seconds, let go, reconnect battery and power the phone on. This works for many. If that still doesn’t work, as in my case, reconnect all connectors, and plug phone into a charger and then power on. This “fixed” mine, even though it had 70% charge at the time of repair. Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
my iphone 6 turns on with old screen it was cracked so replaced it and also replaced the battery to be sure . I put the old screen back on and tried to hard restart and the screen came on and showed the download screen. so i turned it off and put the new screen back on and when i got the connections on i turned it on and the screen turned on so shut it off again and finished putting it back together and now it won't turn on again even trying to hard start it again I hear it on itunes but it shows nothing
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This also works on the 8. Too bad I already replaced the phone with the 12 before I saw this thread to unplug the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I had my screen replaced because it was cracked but now when the phone rings it locks up my phone. I have to wait until the battery is dead before I can even turn it off. I charge it and it works until it rings. Does anybody know what could cause this?
댓글 달기
귀하의 답변을 추가하세요
Steven 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 70
30일 전: 338
전체 시간: 82,164
