Unveiled in 1999 as Apple's portable computer for consumers.
302 질문 전체 보기
will power up, but has black screen
makes the sounds at start up but screen doesn't light up
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
What happens when you connect to an external display?
And if you shine a flashlight on the screen can you see anything?
의 답변
의견 추가하세요
1개의 답변
선택된 해법
What model iBook G3 do you have? Is it a white iBook with a processor between 700MHZ - 900MHZ? If so, and there is no faint image on the screen, you likely have the very common G3 video issue, which often presents the symptom you mention. Try powering on while clamping the machine with your hand just to the left of the trackpad, pressing from top and bottom with a significant amount of pressure (but not enough that you squeeze the hard drive). If the screen comes on with pressure applied, you've got the video issue. If this is the problem, you can read some of my previous posts concerning what can be done to relieve the issue (although, unfortunately, most fixes are not permanent, and the only permanent fix is not cost-effective considering G3s have very little monetary value at this point).
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Very good answer +
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
JERRY 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 1,785
