주요 콘텐츠로 건너뛰기
Hands-free voice-activated device by Amazon powered by Alexa Voice Service. Model S04WQR.
14 질문 전체 보기
Alexa can't set alarm for me. Says is a problem when I ask.
In past could set alarm by asking Alexa to set alarm for a time specific. Now she says alarm set...then few seconds later say problem setting same. Help, thanks and Happy New Year.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
I have 8 echo dots covering 3 generations...suddenly today only the first gen dot is able to understand what a timer is. The others reply with..."Hmmm, I'm not sure". Oddly, when I ask them how to set a timer they respond with, "say something like, Set a timer for 5 minutes", but when I do, I still get, "Hmmm, I didn't understand" or" I don't know that one".
댓글 달기
답변 5개
가장 유용한 답변
I had the same issue. My Echo Dot was connected to wifi and would interact and tell me the temperature.
Every time I tried to set an alarm it would take the command, and then about 5 seconds later respond and say it had a problem setting the alarm.
After reading this post I decided to try power cycling it. That seems to have worked - it took the command. It also is showing up in my iPad Alexa app.
Problem solved.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
There is a problem connecting to the amazon alexa service. You should check if it is connected to wifi, and if so, if the wifi is connected to the internet.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Sometimes Alexa enabled device like mobile app does not support alarms or timers.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Open the Alexa app. On the side menu, go to reminders and alarms, click the alarm tab and push the button to the on position
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just go to settings and choose factory reset option.
Follow the instructions and your problem will be solved…
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Larry Hirsch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 48
30일 전: 94
전체 시간: 22,245
