주요 콘텐츠로 건너뛰기
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 질문 전체 보기
Help Broken Charger Port!
When my phone was finished chargong the other day, I pulled the usb cable out and the flat pin from inside the charger port came away with the cable.
Is it quite easy to replace the port? I have done this with other android phones but never with an xperia
thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Janie,
If you have replaced the charge port on another phone, you should be okay. I would recommend a good quality low melt solder paste as this will make the removal of the shielding easier. (Just remember to remove all the low melt solder before soldering the new charge port on or you will have connection issues)
Hope this helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Janie Campbell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 634
