주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.66, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
298 질문 전체 보기
Power up without internal keyboard
Hi,
I recently spilled liquid on my MacBook Pro 15" Unibody Mid 2009. It will only turn on if I disconnect the keyboard ZIF connector. Too bad the power button is part of the broken keyboard. Is there any way to "jump start" that model?
For older and newer MBPs I have found information regarding how to do that (always shorting to pads on the logic board). Where are those pads on the logic board of my model?
Best Benjamin
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
See this
Answer for a 17" machine. Your solution will be similar look for the description power button - you may need a magnifying glass.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks. For the pre-unibody MBPs this task was quite easy. But the newer models have no markings on the PCB.
댓글 달기
귀하의 답변을 추가하세요
Benjamin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 5,962
