Small crack on display's chin bar
Hey guys
The bottom chin bar of the screen cracked as you can see in the picture.
What do you guys think about it?
Should I just try to send the laptop into warranty or can I buy just the chin part somewhere?
좋은 질문 입니까?
댓글 23개
Hopefully you got the extended AppleCare. If not give them a call and get signed up ASAP!
Then wait a week and visit he Apple Store. As it should be then covered under the extended warranty program (double check the fine print).
As Reece stated parts are just not available yet as this is such a new system.
Besides, replacing the display assembly will cost you more money than signing up for AppleCare and will take a bit of time to get.
I would strongly recommend you get a good case in the mean time.
Dan 의
Thanks for your replay Dan! The computer is from work and they got applecare on it.
Problem is that the screen cracked because my 3.5mm headphone jack was between my screen and the computer when I closed it. So I guess this does not fall under the AppleCare warranty.
Any advice?
Joris Dubois 의
There is two different AppleCare's: The one you get when you buy the system and a second which you buy that extends the coverage.
As the system is so new you still have the standard warranty coverage. That doesn't cover bangs or other minor mistakes. If your company got the extended coverage then your good to go! (again double check the fine print as I haven't seen the latest version of the contract). You might be able to get it done for Free! I would take it in, all they can say is no. But don't give up to easily here, push a little and have a sad face (even a tear running down the face helps) ;-}
Otherwise, it will likely take a good 4 months before parts will be readily available. And then it's a matter of how hard it is to replace the screens cover glass (if it's an independent part) and/or how hard it is to replace.
I'm sure Apple is moving to a fused cover glass like the iMac series, so that would mean the complete LCD panel unit would need to be replaced, Ouch!
Dan 의
Almost the exact same thing happened to me... and it's sad there are no spare parts available anywhere right now.
knny.myer 의
I have a small crack on the right size of my Late 2016 MacBook Pro display. It is about 1.5" to left from the right side. Just directly above the small crack there is a vertical line. The screen to the right of the line is blank while the rest of the screen works fine for now. I went to Apple Store b/c it is within yr of purchase and they assumed something got caught b/w display and computer when screen was closed and said it was a "pinch point" there. They then told me the problem with crack had nothing to do with the screen going dead directly above crack. Needless to say they wouldn't do anything unless I paid a $700 fee to replace the entire display. Getting tired of Apple's BS.
Matty 의
댓글 18개 더보기
