주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1438 질문 전체 보기
iFixit Replacement Battery Not Charging or Reading % right
Hi all,
I ordered the battery replacement kit for the iPhone 6 Plus and followed the replacement guide as closely as possible. I did run into trouble with the adhesive but eventually got the old battery out. When I put the new battery in, I found the connector didn't set very nicely, but I believe it connected, as well with the other connectors (the digitzer, etc) up top.
After reassembly I turned the phone on and was just happy to see it turn on successfully. After a few hours of use though I noticed the battery percentage wasn't reading right. It would keep flip flopping between numbers like, 12%, 9%, 12% again etc. I thought maybe a calibration would help, but when I let it charge overnight I noticed it didn't charge at all and stayed at 9% all night.
I'm really nervous and upset about this and hoping for some advice or help.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
지금 장보기
iPhone X Fix Kits
지금 장보기
3개의 답변
선택된 해법
If you bought a bad battery from iFixit. Just hit em up. They're pretty good at honoring they're warranty. I think I've had to do this twice in the past year or two. They respond and ship IMMEDIATELY
해당 답변은 도움이 되었습니까?
점수 5
의견 추가하세요
Sounds like a dudd battery, id contact the vendor for a replacement, even official apple batteries can be faulty.
해당 답변은 도움이 되었습니까?
점수 4
댓글:
Went to a repair place today and the battery was swapped out for one they had. Worked perfect after that. I bought the battery from on here. Bummer. Thanks for the reply.
의 답변
의견 추가하세요
As rayeasom says, absolutely replace the battery with another one, preferably one that is known-good, perhaps from another device.
If it fails, it is indicative of a charging problem on your logic board and requires a micro-soldering repair.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Dalaney Vartenisian 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 8
전체 시간: 494
