주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
My the device doesn't turn on.
Hello all,
I have this issue with an iPhone 5s. The screen went blue a couple of times then after a while the device didn't turn on anymore. I'd like to invest some time and money into trying to fix it, even if it doesn't worth it overall, for the sake of learning.
So, I checked the battery and when fully loaded the voltage seems to be fine. From reading other forums I found out that the main board or the logic board may be the problem. Is there way to diagnose it? I would clearly buy a new one from eBay and try to replace it if that's the case.
Where else should I look? What else can the problem be?
Thank you for taking the time to read this!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I would avoid eBay, it's kind of like playing the lottery. I would buy two parts from iFixit
First I would buy this
iPhone 5s Battery
Likely your culprit
You could need to buy this
iPhone 5s Lightning Connector and Headphone Jack
I'm guessing you'll need one or both of those, if it's the board, you'll want to send it out to a repair service, like iPad Rehab
iPhone 5s 배터리 교체하기
iPhone 5s Lightning Connector Replacement
iPhone 5s Battery 이미지
상품
iPhone 5s Battery
$29.99
iPhone 5s Lightning Connector and Headphone Jack 이미지
상품
$24.99
iPhone 5s 배터리 이미지
안내서
iPhone 5s 배터리 교체하기
난이도:
운영
30 minutes - 1 hour
iPhone 5s Lightning Connector 이미지
안내서
난이도:
운영
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Does the phone not turn on or does it not display? Trying flipping the vibrate/mute switch and see if it vibrates. Also try plugging it into itunes to see if it recognizes it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
iTunes doesn't recognize it. It's fully off :(
댓글 달기
귀하의 답변을 추가하세요
VRad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 60
