latched is locked with the door open
The door is open and the latch is stuck in the locked position. tryed to bypass but will not work. how do i remove the frount cover to check to see if the part is working.
좋은 질문 입니까?
좋은 질문 입니까?
The door probably thinks it is already closed and the lever is pushed forward in the lock position. Use a screwdriver to push it back. That failing here is the replacement part: http://www.repairclinic.com/PartDetail/D...
해당 답변은 도움이 되었습니까?
So, I tried that but not sure which way to push it looks like it rolls up and I need to push it down but it will only allow me to roll it so far then stops
Any other thoughts?
Oh, I have a HE4T
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 3,105
댓글 1개
I have the same issue....any answers????
Andrew 의
