주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
Wont connect to itunes
The iPod charges sort of ok. I will plug in the charger and after like 30s it will start charging. If i plug it into my computer itunes doesnt see it at all. Should I replace the logic board?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I swapped the mobo out for an 820-1975-A mobo. Granted the hdd was 60gb, it still worked and all 60gb were seen by the iPod. Connects to itunes and charges too
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
No, sound like a battery
iPod 5th Generation (Video) Battery Replacement
https://www.google.com/search?q=ipod+5th...
해당 답변은 도움이 되었습니까?
점수 1
댓글 6개:
I just replaced the battery with a new one. It charges fine, just it wont connect to itunes
What cable are you using? Is it an aftermarket one?
Nope regular apple one. Its weird because the cable will charge and connect other ipods to itunes, but it only charges this one. It will not connect to itunes
And the charging port is soldered to the logic board. It would be cheaper to try the charging port, but not easier than changing the logic board
I have some spare logic boards. Should I try replacing it with a 820-1763-A or an 820-1763 board?
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Vlad Nikolayev 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 62
