주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
4039 질문 전체 보기
Possible Antenna issue effecting signal
Hi there,
I have a iPhone 5S on three which was working fine up until yesterday when the network ended up being stuck on searching. I managed to perform an update and this went away and it started to recognise the network, but then I noticed the signal kept going and it would say "No service".
Curious, I lightly tapped the bottom side of the phone and the signal came back. Now when using the phone, the signal drops and I have to tap it to get the signal to come back. My assumption is that the antenna must be loose but before I go opening up, I thought I'd see what you guys suggest here and double check exactly which antenna effects the mobile signal.
It's not longer under warranty as it's 3 years old.
Many thanks!
Stacey
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
Not likely as the antenna is screwed in to the frame, even if its unstuck you should get a constant 1-2 bar signal in urban areas, more likely its IC related, in that a network IC is loose, given the model it may be a better bet to upgrade, we have attempted hot and cold treatment which lasts 1-2 weeks but permanent fixes are hard to come by and expensive.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
That's a shame. I've literally just upgraded to a 5SE and took out a sim only year contract for my wife to use that phone; so upgrading isn't an option now :(.
의견 추가하세요
귀하의 답변을 추가하십시오
whiteforestdogs 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 65
