주요 콘텐츠로 건너뛰기
A smartphone manufactured by HTC released in February of 2016.
6 질문 전체 보기
My phone wont charge
I've had my phone 3 months and I've never damaged it in any way. Yesterday my phone stopped charging. I tried the power button and volume button trick but it doesn't work. When I turn on the phone it's on 3% all the time and when you plug it in an exclamation mark appears on the battery symbol. Then it turns itself off. When you try turn it back on a big battery and exclamation mark appear on the screen. This has happened twice before and I've fixed it with power button trick but it doesn't work this time. The battery is not removable.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
I had this problem twice. Replacing the charger worked.
의 답변
의견 추가하세요
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
5개의 답변
가장 유용한 답변
@tomas_om since you've only had your phone for this short amount of time, replace it under warranty. It does sound like either a battery or a logic board issues.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I'm about to tear my phone apart and see what's going on with it since I'm having the same issue. I got it used, so nothing lost.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Get your charger replaced.
의 답변
의견 추가하세요
You should put it in boot mode and the phone should charge but dont reboot until 15-30 min have passed to get around 5-10% to use
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I have the same problem on my 530, it's look like a problem with charging-port and battery, i used it on various chargers when the original charger pasts-away deadly, i think that is the problem for my case,never shoulds charging smartphones with other chargers,should be the original charger every time .
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Not necessarily. I have a charger with three different ports. It works for my flip phone AND my Kindle Fire. You should get your charger replaced.
의 답변
의견 추가하세요
Replace the charger.
Sometimes a charger gets worn out from being in a certain position for so long.
If you keep using the old charger, it will only charge in a certain position.
You should get something like this...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Tomas O Miachain 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 38
전체 시간: 2,370
