주요 콘텐츠로 건너뛰기
Apple의 21.5" Intel iMac 수리 안내서 및 지원
2084 질문 전체 보기
Repair Windows 10 Bootcamp on iMac
I have an iMac with a Mac OS partition and a Windows 10 Partition. I wanted a way to share files between the the OS without using a USB to transfer the files every time. so I created a new partition using some of the empty space of the Mac OS partition and formatted it as MS-DOS so that both OS could read and write to it. However, now when I go to boot into Windows it encounter a problem and won't boot. It says I must use a repair program to fix it. I went to the Mac OS partition and deleted the new partition and it still won't boot. What would cause this to happen? Its done it twice and I had to reinstall Windows as I wasn't able to make a bootable USB to use the Windows installer repair program. I used the terminal and the dd command to create a USB with the windows .iso file but when I hold the option key at boot the mac doesn't see it. How would I properly make one that way the mac can detect the USB so I can use the repair program?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
You will need a blank USB 8gb or larger for this.
1) Go to Applications --> Utilities, and find the Bootcamp Assistant.
2) Run the Bootcamp Assistant and follow the prompts
• it should correctly partition/repartition your drive for Windows 10, you can skip this
• after the repartition step, there is an option to create a Windows installation disk using USB
3) Also use Bootcamp Assistant to create a Windows drivers disk on USB
• if correctly installed, Windows should have access to the OS X part of the hard drive without reboot
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
CAB 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 31
전체 시간: 13,420
