주요 콘텐츠로 건너뛰기
A 12.2-inch "prosumer" tablet released in February 2014. Powered by a custom version of Android 4.4 KitKat.
40 질문 전체 보기
How do I fix the wifi, it won't turn on
When I move the setting to wifi on, it just turns grey. The same happens with Bluetooth
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@tbow2k ,Tom. I found a suggested fix from a forum 1st link below, remove battery, hold down power button 30 seconds, reinstall battery and power on.
Other things to check would to be up to date on firmware. Link #2 is Samsung trouble shooting on WiFi etc. where you can input info. and hopefully get a solution.
Factory reset is probably the last thing you want to try, last link explains the process. Good luck.
https://forum.xda-developers.com/galaxy-...
http://support-us.samsung.com/cyber/popu...
http://www.hardreset.info/devices/samsun...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Tom Bowman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 978
