Samsung HD TV Will Not Connect To Cable Box
We just bought a new Samsung HD Smart TV? Took forever to hook up to our Xfinity Box. Yesterday lost stations on that TV. Xfinity said the box was bad and we had to get a new cable box. We are on the 2nd one today and can not get it to connect to the TV. Says no signal.
HELP! It worked on another TV in the house but not this new TV. Any suggestions would be most appreciated. Thank you in advance . FRUSTRATED!
좋은 질문 입니까?
댓글 14개
What model is this TV? all you are connecting is the Xfinity box?
oldturkey03 의
Yes. We are supposed to get a new box today. We will see if it works. I do not have the model number with me right now.
Tammy Pyrdum 의
How have you connected the TV to the box with the antenna cable, HDMI cable, scart cable or component?
Have you used the cycle throught the source button on the TV to see if it finds the box on any of these?
Claes 의
We got the new box. Tried it with the antenna cable and HDMI cable. Neither worked.
We moved the TV into another room and it will hook up to the box just fine. But not in the den.
The cable in the DEN is run from the attic to basement and up through the floor (not a jack). On this cable line is a splitter in the basement which the other cable goes to the bedroom. The TV in the bedroom is working fine.
We see nothing wrong with the cable coming to the den. We have also hooked another TV up in the den to the new box ..it does not work either .
However, we can bring one of our old smaller boxes into the den and it works with the smaller TV but will not work with the new TV.
NOTE: Cable Antenna is not listed as a source on the new TV.
Tammy Pyrdum 의
Hi, Is your smaller box or smaller TV capable of given you a signal level/ quality reading? Usually in TVs and boxes there is a menu item that allows you to check signal level and quality. It may be that the splitter is faulty and that the level or quality of the signal is too low for the new box or the TV.
Also what is the model number of the new box and the new TV?
jayeff 의
댓글 9개 더보기
