Not turning on at all.
Help. My Asus laptop wont turn on period. The screen will glitch and i cant get in to the BIOS. Anyway to fix it?
좋은 질문 입니까?
좋은 질문 입니까?
First step is does your device have a power indicator Lots don't. Have you tested the power cable on another device. usually tablet power connectors are mini or micro USB so you can try another phone cable on your tablet also it might not have as much power but it will trickle charge
You say screen glitches if this only when power button is pressed would indicate low power
Also check non of the USB or HDMI pins are touching on device will cause tablet to also cut out
Sometimes simple things cause complicated problems
해당 답변은 도움이 되었습니까?
Thanks. I will open it up and see if the pins are touching.
How am I supposed to get to the pins?
There are 4 flat pins in female USB ports were you would usually insert stick etc sometimes they get bent hope this helps
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 1,785
