주요 콘텐츠로 건너뛰기
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
87 질문 전체 보기
My Xbox 360 wireless controler wont do anything.
So I got a used Xbox off Craigslist and some of the remotes had battery acid corrosion on them. So I clean them with lemon juice and now nothing happens when I try and turn them on nothing happens. NOTHING!!!!! Please help!!!!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
3 댓글:
Were are the battery contacts and how do I know if they are bad? Does it make a difference if I'm using AA's or not?
Yes you need to use aa batteries, along with the battery shell that the batteries fit in to. The contacts are just the metal part where the batteries sit on top of. Make sure they are not corroded or bent otherwise the controller won't be getting power from the batteries
Ok how do i know if the battery contacts are bad
댓글 달기
답변 1개
Hi you would need to dismantle the controller and clean the battery contacts with isopropyl alcohol and a toothbrush, if they are really bad and that doesn't work, then you would need to buy replacement ones
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The battery contacts are the metal part where the batteries sit and if they look corroded then most likely you would need to purchase replacement ones and solder them on
댓글 달기
귀하의 답변을 추가하세요
Parker Collins 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 1,054
