주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3356 질문 전체 보기
iPhone 5 shows red empty battery with charger plug but doesn't charge
I broke the screen on my iPhone 5 and replaced the screen, as I have successfully done before. When I plugged it in (it had run out of power just before the screen broke) I see the graphic showing an empty battery (red on one end) and a charger plug being inserted, which is what I've seen when it's charging but doesn't have enough charge yet to start up. But, even after leaving it charging for a while, that image never changes so it seems like it's not charging at all.
I'm not sure what to do. I may try to get a new battery but it seems strange that the existing battery would just die like that so I'm thinking maybe the impact had loosened something but all the connections seem ok.
Any idea what I should look at?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
3개의 답변
선택된 해법
So right now the iPhone shows low battery icon with plug in charger image at the bottom right?
You plug in the charger and it still shows the same thing with the plug on bottom right?
If yes then check the charging cable to see if it plugs in fully. If it doesn't then there is something stuck inside the charging port usually debris.
You can use a toothpick or something equivalent tweezers for example to clean the port. There are 5 pins that push down on the bottom side of charger port. Make sure you don't touch them when cleaning.
Otherwise if still no good probably a bad charger port.
해당 답변은 도움이 되었습니까?
점수 6
댓글:
The image is roughly in the center of the screen--maybe closer to the bottom than right in the middle--but not on the bottom right. I will try to clean the port...I hadn't thought of that.
의 답변
I took a toothpick and cleaned out the charging port and that did the trick! Something might've gotten in there when the phone was dropped. Thanks - I'm accepting this answer.
의 답변
Cleaned out port(carefully ) with tiny
Plastic pick, cleaned cable end and reinserted. Now charging-shows 4%
Thanks
의 답변
Brilliant tip, thanks a lot!
의 답변
의견 추가하세요
If the Phone was Off for a while u need to leave it in High output Charger for hours and try power on later
해당 답변은 도움이 되었습니까?
점수 0
댓글:
From what he wrote it seems his phone was not dead for too long thats why he's wondering why it won't come on
의 답변
try new battery, another charger and se what happens, this will narrow down the possible cause.
의 답변
Yes, I had just run out of power and, as I was on my way to recharge it, so it hadn't been dead for a while. I was wondering if the connections within the phone could be shuffled in a way that would cause a charging problem.
의 답변
This is a 4 year old 5S 32GB, I gave it to a Technician - Vedict - The Motherboard is gone hence cannot be used further as motherboard is non-replaceble. Checked/changed all the Charging Ports, Changed Battery - all in vain.. it is just gone -----BLANK.
is there a resolution to this problem.....
의 답변
의견 추가하세요
If this is the original battery then you should just replace it. they are not expensive and you get to stop worrying about that too.
Mike
해당 답변은 도움이 되었습니까?
점수 0
댓글:
My concern is not the expense of the battery but whether it is the cause of the problem. If it's not, it would be a waste regardless of whether it's expensive or not.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
James 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 22
지난 7일: 218
지난 30일: 964
전체 시간: 42,017
