주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2683 질문 전체 보기
Why won't my iPhone charge (Liquid Damage)
My phone fell in water. But it still turned on and worked normally. Then i tried to charge it the next day and the charge symbol was on but it would not charge. Then later in the day the charge symbol would not even appear. I took it to a shop and they tried switching both the battery and the charge port, but its not either of those. The phone still works but it won't charge, please help if you know what i can do.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
You need to clean that bad boy! An ultrasonic bath is really the best option. But you could possibly get away cleaning the logic board with a tooth brush, and 90% isopropyl alcohol. You also may need to have the u2ic replaced, for which you'll want to send it off to a board repair shop
Weird. There's no logic board replacement guide. Guess I'll have to make one. Pay attention to the octagon screw, I use a needle nose for right now
iPhone 6s 분해도
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
you have to cleaning the logic board with a esd brush and 90% isopropyl alcohol. If this does not working you need to replace the u2 ic which needed micro soldering so, you have to send it to the repair shop
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Oscar I agree with the previous answer and want to add one thing TURN IT OFF AND DO NOT TURN IT BACK ON OR CHARGE IT until you have thoroughly cleaned it. Every time you turn it on or charge it you are shorting out another component. Its like a domino affect, the next time you power it on may be the last because eventually you will short out a major component which it sounds like you may have in the U2IC chip mentioned by medic. On top of cleaning it you will need to order a new battery and possibly a new screen (I would suggest from this website). Typically neither survive the initial water damage and if they do they eventually fail. Just some extra information.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Haha. This guy cracks me up
It was the caps, and the scotch...
True its like yelling and then talking low lol!
댓글 달기
귀하의 답변을 추가하세요
oscar garcia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,489
