주요 콘텐츠로 건너뛰기
Why full speed Fan and loudly iMac 27 mid 2011
Hi Please I need Help !
long story , I took my Imac to apple care for replacing Video card because the vertical green line conman issue . then after they replace it , it work fine .
problem start when I try to upgrade HDD with New HDD .
I did replace the HDD then I finished reconnected all the cable of LCD. when I turn my Imac I smell something got burned !
I found out the connector (molex ) of the Display Port Power Cable got burned and also one small chip below the connector too .
so I disconnect all the cables of LCD, I did reattach the old Original Apple HDD , I contact my Imac Via TV by HDMI Cable , it work fine bootable I reached my desktop file . ! but the Fan work Loudly and full speed .
- I installed ( HDD Fan Control ) application it show , HDD 1024 PRM , ODD 3234 PRM , this app couldn't solve the problem or control the Fan I tried all option of app Auto, Manual, Smart .
- Idid SMC reset and PRAM reset nothing solve
a) my question first : is there hope to use LCD which option I must go with on this case :
1- got new Display Port Power Cable only !
2- replace the cable + connector (molex) + the small chip
3- replace the logic bored
B) my second question : I can live with Via Monitor rather than using LCD but
how I will solve the problem of full speed loudly fan !
I wonder if the burned chip could effect the logic board .
I did attach Photo on the Link below :
Notice : done SMC reset and PRAM reset nothing solve
Thank you for your time anything will be helpful
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Let's start with the run away fan issue. Get this:
OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade
https://eshop.macsales.com/item/OWC/DIDI...
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Thanks mayer i reattach the Original HDD that came with Imac 27 mid 2011 . I don't think I need OWC , unless I will make upgrade for new HDD . However, I did ordered OWC it's under shipping now .
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Mr. MAC 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 33
전체 시간: 1,332
