samsung charger port wont work
charger port wont charge
좋은 질문 입니까?
soul524 the charging port is soldered to the motherboard. you will have to disassemble your phone and replace the port. This video is almost identical to the way you will have to repair your phone. Replacement ports are available at places like this.
해당 답변은 도움이 되었습니까?
soul524 around $10USD if you buy the ports from places like this. Use this video for your repair.
해당 답변은 도움이 되었습니까?
@oldturkey03 , Just thought this was a little strange, maybe was it to be addition to your original answer?
From my experience the core prime has a slightly different micro USB port, there is a raised section in the port which requires a charge cable with the corresponding relief.
Or the port is totally dead
해당 답변은 도움이 되었습니까?
I will be getting an android phone but the charger port is blown how can I get it fixed
해당 답변은 도움이 되었습니까?
Either look up YouTube videos and do it yourself or take it into a nearby cellphone repair place.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 1,571
댓글 1개
soul524 have you tried a different cable and a different charger? Does it charge when you "wiggle" the cable in the connector? Does the connector looks damaged?
I have noticed that you have three questions related to the charging port. Are all of these questions related to the same phone?
replace charger port on samsung
How much is it to replace my charger port
and the current one
oldturkey03 의
