Routing clutch cable from deck to engage lever
I gave craftsman model no 917.289223 and am replacing the clutch cable. What route does the cable take from the spring on the mower deck to the engage lever under the steering wheel?
좋은 질문 입니까?
좋은 질문 입니까?
@houseofdavid , David , You may have to remove the gas tank if in the way, cable loops behind deck, then gets secured in a wire hanger or if missing, tie strap(use a couple) as you feed cable along, to inside frame rail/body above deck feeding it up to the control lever through slot/hole/opening. It is actually easier to hook cable up to the lever first and feed down from the top along frame rail attaching as you go with a few plastic tie straps as you go. Links below may help a bit. Good luck.
해당 답변은 도움이 되었습니까?
L Pfaff- Your answer helped a lot. I had some trouble when I installed the cable, tho. The plastic piece that holds the cable covering in place and lets the cable slide broke off when I tried to engage the blades. There was quite a bit of tension on the cable which caused the breakage. Is there any way to adjust the tension?
There is a "L" shaped bracket on the deck near the spring that has some adjustment. Is that where I need to make an adjustment? What would cause the tension on the cable?
David, Sorry to here you had a little problem, tensioner arm may be seized, with belt and cable off check to make sure the swivel point/bolt for the tensioner arm is not seized up as they usually do(should swing very free) and I do believe there is adjustment with the bracket you are talking about.
There is no such item, as a tensioner arm, listed anywhere on the parts diagram!!! What is the correct name of the part of the number used for the part in the parts diagram???? Is a high resolution photo of the parts diagram available. The online manual has one, but the quality is so poor that absolutely no detail is available!!!!
I am having the same problem. Clutch was getting very hard to engage this year then it broke. Bought and installed a new clutch and it is impossible to engage even with 2 hands.
Did anyone get a helpful answer on the routing diagram 917.27313?
Why wont it stay running when I put it in for the deck to mow
해당 답변은 도움이 되었습니까?
Hey Penny. Please find & post the model number for your mower. Also maybe tell just a little bit more about it, like if it's been working fine until...., or you just got it, used, or if any other work had been done on it recently, etc., as this information and recent history can really be helpful in trying to come up with something helpful.
Hey Craftsman,please show a ledgable diagram for routing the deck cable from top to bottom!!!!!!
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 36
30일 전: 122
전체 시간: 8,092
