주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2008년 10월 출시 / 2.4, 2.53, 2.66, 2.8 또는 2.93 GHz Core 2 Duo 프로세서
478 질문 전체 보기
SSD upgrade in old Mac, not being recognized
Ok so here's the gist.
I have an old Late 2008 Macbook that the hard drive crashed on and I replaced with a new computer a few years back. Now my kid is old enough to have a laptop and I thought it would be easy to just replace the hard drive.
I bought a PNY 120GB SATA-III SSD model: CS1311
I used a SATA adapter to plug into my newer mac to format the hard drive
I created a bootable OS X Sierra on USB
The only problem I am having is that the 2008 Mac does not recognize this new hard drive. The USB will show up when running Disc Utility from the startup menu, but not the new hard drive.
I have searched forever on forums looking for help but have found nothing that works.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
선택된 해법
You made a couple of mistakes here.
Did you check to see if the SSD drive you got is backward compatible to Serial ATA (3 Gb/s)? It is, but not to SATA I.
You did your work on a machine that the drive is not going into.
You did not check to see if Sierra was supported on this machine (it is not).
Pre-Installed MacOS: X 10.5.5 (9F2114) Maximum MacOS: X 10.11.x*
You would probably do better with a SSHD.
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
귀하의 답변을 추가하십시오
JAubry 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 671
