Why is my mobile phone not charging
battery is good,the only problem is when i connect the charger,it does not charge
좋은 질문 입니까?
좋은 질문 입니까?
byahero_132 , We really do not see this phone in North America. Since you state you know battery is good, either the cable or battery connector(link #1) may be damaged. Look at the charge connector and blow/pick out/ wipe any dust/debri that may be causing a connection issue. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, it is probably a damaged/loose charge connector that will have to be repaired/replaced. Sorry was not able to find guides or video's showing the process of repair, you can try a search and may have better luck. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
해당 답변은 도움이 되었습니까?
Thank you very much for your response to my query....
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 3,359
댓글 1개
My cherry mobile cubic morph he charge up to 66% only
Plss help me how to fix it
shariffbuklao27 의
