주요 콘텐츠로 건너뛰기
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
103 질문 전체 보기
My phone wont charge even when other functions are off
i charge my phone and the power wont move or will continue to decrease with any use at all. other days it works perfectly fine, but randomly it wont hold power.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
millerm09 , A lot of forums feel a factory reset can fix this type of issue, read and follow the steps in the first link below if you would like to try, all data not backed up will be lost.
Reset did not work, either the cable or charge port may be damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix, it is probably a damaged/loose port that will have to be repaired/replaced. If port looks/test good the battery or connection is probably bad. If port is found to be bad, this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the tablet to check the charge port and will also post a link showing what is involved in repairing a mini USB attached to the board. The last link is to new charge port, which you can also do a search for better pricing perhaps if needed. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. Good luck.
http://support.bell.ca/Mobility/Smartpho...
Alcatel One Touch Idol 3 LCD Display Replacement
https://www.youtube.com/watch?v=bl0k5EyI...
http://www.ebay.com/itm/Micro-USB-Chargi...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi, this has happened to me several times before, and most of the time you have to ccheck if you have an original apple charger and base of the charger. If it still isn't working check if it charges on another person's charger or if another phone charges into yours.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
millerm09 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 482
