주요 콘텐츠로 건너뛰기
Why my laptop monitor become black?
Usually (about 50%) my laptop monitor became black when I turn it on or sometimes between working .....but when this trouble fall the laptop continue working e.g. when I watched a movie suddenly the monitor becoming black but the movie be continued and the touchscreen works without any problem ,because I can pause or play movie with touch it when the monitor is black
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Hi,
Try shining a torch at an angle close to the screen (when it is black) to see if you can detect a display at all. It will be dim, so a darkened room will help.
If you can 'see' a display then you have a problem with the backlighting. This could be a video cable problem, a backlight power supply problem or even a lid switch problem. The lid switch controls the backlighting either through software control or a direct power connection through the switch itself, I'm not sure which in regard to your particular model
If you can't see a display connect an external monitor to view its' display.
If it stays OK when the laptop's screen turns black you either have a faulty video cable, faulty or loose video cable connections at either end, (motherboard or screen), or a faulty screen.
If it also loses its' display, you either have a faulty GPU or a motherboard problem (which is probably the same thing as the GPU is most probably mounted onto the motherboard).
You could also try running the laptop in 'safe mode' in case it is a graphics driver problem. In 'safe mode' Windows only loads the basic drivers.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
The video harness that connects the LCD to the motherboard comes loose on this model. You'll need to open it up, and reseat it. Fairly straight forward. Problem is that it doesn't want to stay seated. Still working that out.
Hi Thomas, What about using tape like the phones do?
댓글 달기
귀하의 답변을 추가하세요
kaveh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 1,171
