Model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair.
204 질문 전체 보기
R1 Button sometimes registers two presses when I only press it once
So I've noticed that my barely months old DS4 has been behaving strangely in regards to my R1 button. Sometimes - not all the time, but sometimes (particularly in games like Warframe and Neverwinter, where R1 is/can be mapped to a quick action) pressing R1 will have the game respond as though I've pressed it twice very quickly.
R1 is the only button that does this as far as I can tell, the button isn't loose, and I've been treating the controller like it's gonna break ever since I bought it, since it was a purchase to replace a different controller that also broke on me.
One of the screws stripped on me (the screwdriver was the right size too, I made sure) so I can't open it up to see if there's something gone wrong inside. Beyond buying a whole new controller, I was wondering if there's anything I can do to fix this? I don't have the money to buy yet another new controller - these things cost a fortune, and I refuse to buy one used.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
가장 유용한 답변
Seven Lexar , Perhaps you would like to try returning under warranty for replacement at the bottom link. If not wanting to return you may have to carefully use a power drill with small metal bit to drill the head off screw and once apart remove remaining screw out with pliers/ small vice grips. Perhaps parts from one of your old controllers will suffice. 1st link will show how to access buttons so you can check for dust/debri/etc. and clean. Good luck.
DualShock 4 Buttons Replacement
https://support.us.playstation.com/artic...
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Seven Lexar 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 213
