Won't Turn on unless charger is plugged
Hello gud day. MY Huawei Honor 6 wont turn on unless charger is being plugged in. Once you unplug the charger it will give you a black screen and will never turn on again :-) pls help me
좋은 질문입니까?
좋은 질문입니까?
The battery in your phone is likely at fault. A very strong indicator is that the phone only functions when connected to a charger. Once unplugged it powers right back off definitely points towards a battery issue in most cases. Seems possible the honor 6 does not have the most reliable batteries. I say this because I have helped others with the honor 6 that where having boot loop issues. The boot loops were caused from a failing battery that was not able to supply enough current to fully boot into the operating system. The batteries would only supply enough current to power on the device. It takes more power to fully boot into the operating system than it does to simply turn on the phone. That is why they were experiencing boot loop issues. The battery was failing and was not able to supply enough voltage. The sad thing is a lot of these people had taken there phones to a service center where they were told it was a motherboard issue. I recommended them try a replacement battery as I did not trust the service centers diagnosis and had a feeling they were trying to take advantage of people. I was correct to say that because most were able to fix their issues with a new battery.
So I strongly suggest getting the battery replaced. You may want to check out this post too.
이 답변이 도움이 되었나요?
I had the same problem with my honor 6. I brought it for repair and it worked again when I had the battery replaced. But after few days, it went dead again, now no signs of charging, hard reset, same, it doesn't even show the logo when you try to reboot it, it's just dead... Now I hate this phone, just wanna throw it away. I even spent money trying to fix it, it just sucks. It got worst. I better up used the money in getting a new phone, this time not huawei or honor. Don't trust it anymore...
이 답변이 도움이 되었나요?
지난 24시간: 3
지난 7일: 9
지난 30일: 35
전체 시간: 9,686
댓글 1개
I have thesame probleme with my mate1. mine started when my phone fell down
Maimuna abdullahi 의
