Why my phone doesn't charge and won't turn on?
My brother got mad and threw my phone, nothing cracked but it won't charge and turn on, the battery is at 90%-100%; is there a way of fixing it?
좋은 질문 입니까?
좋은 질문 입니까?
@vitslit , Vit , You could try a factory reset, doing this will loose all stored data and there is no guarantee it will fix the phone or you can open the device using the 2nd link as an aid to get inside and look for any damage to be repaired, check/reseat all the connections and then try phone. Other alternative is to take phone into a good local cell phone repair shop have them take a look, diagnose, estimate repair, decide if you want to go ahead with repair and give your brother the bill.
Factory reset procedure from link below.
1. Ensure the device is powered off.
2. If device is on, press the power button and select Power off. Tap OK to power off.
If that doesn't work, remove and replace the battery.
3. Press and hold the Volume Down button, the Home button, and the Power button simultaneously.
Release the Power button when the LG Logo appears and release the other two buttons when the Blue Tracfone Logo disappears.
4. The phone has now booted to the SAFE MODE.
To do a reset, open the lock screen, press Menu Key, select System Settings, select Backup & Reset, select Factory Data Reset. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 4,407
