Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
362 질문 전체 보기
lenovo MIIX 700 and it doesnt boot
I have a lenovo MIIX 700 and it doesnt boot I tried it all and I cant find a reset hole to stick a clip in . I need help
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hello. I have quite same problem, after updating the bios, it crashed, so first I could go to the bios so I did to check settings, and now it continually reboot on the Lenovo logo... Can you help me please? Or is my motherboard dead?
의 답변
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
1개의 답변
선택된 해법
Hi,
Does the tablet indicate that it is charging when you connect the charger to it?
When you say that you tried it all, did you try to reset the tablet using the Volume Up and the Power button to get into the recovery menu? If so what happened?
Here is the procedure:
Shut down the computer and wait at least five seconds.
Press and hold the Volume Up button and then press and hold the Power button, (both buttons are now held together) until the Novo Menu appears on the screen.
Novo menu > System Recovery > Troubleshoot > Reset this PC
Here is an image taken from the user guide that shows the options available in the Recovery menu. Be aware of which option you choose in the Reset menu as you could lose all your data if you choose Remove Everything and restore the tablet to its' factory default condition. Select Keep my files as highlighted in the image.
(click on image to enlarge for better viewing)
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
stephaniexxme 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 31
지난 30일: 152
전체 시간: 3,970
