메인 콘텐츠로 스킵하기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1973 질문 전체 보기
Battery issues after work don on the screen
Hi, I bought an iphone 6s of a friend with the intention of putting a new battery in. What happened was that my friend did a screen replacement, unconnected the battery first and successfully put a new screen on. However after he did this the battery started draining stupidly fast as in 3% in 2mins just with the screen on and not using the phone, faster if the phone is being used. When it is on charge the battery still goes down just not as fast, the only way to charge it is to turn the phone off while on charge, if the battery runs to nothing then it will not recharge!? Its had 2 new batteries just to rule out the battery itself and still have the same issue, i fear he may have damaged the board or something in some way. Any advice would be greatly appreciated.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
I always use origiona chargers, i think this chip you mention sounds most likely, is it something i can reflow with a heat gun or does it need to be sent away do you think?
의 답변
의견 추가하세요
1개의 답변
Did you use a charger or a aftermarket iPhone charger? I think you damaged the tristar chip on the mainboard, it can be replaced but it requires microsoldering.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dez Deakin 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 32
