when I press the gas nothing happens
replaced the battery solenoid valve and voltage regulator still nothing when I press the gas?
좋은 질문 입니까?
좋은 질문 입니까?
Here is a link to wiring diagrams: http://www.courtesygolfcars.com/yamaha-s.... They have both the G22A and G22E. Before spending more money on parts, I would take a multimeter and start checking components.
For example, do you get continuity when the key is turned in the key switch, and do you lose continuity when you turn the key off. If so, then there is no need to spend money on the key switch.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,208
mg101474 what make and model is it and what have you checked thus far?
oldturkey03 의
Its a 2006 yamaha g22.
I've already replaced the battery voltage regulator and solenoid valve.
Next I'm going to try the accelerator switch and the key switch
mg101474 의
I have a g2 1990 that I have the same problem I know there is no spark in the plug
rey12345 의
