water comming in from the waste outlet when water in my sink
water coming in my machine when not on from my waste pipe
좋은 질문 입니까?
좋은 질문 입니까?
sherwoodys , Sound like the washers drain hose may not be correctly installed. You must have the wash machines waste hose elevated/installed higher then the top of sink. Also check the drain/sewer line for blockage and remove blockage as waste water should not be backing up. Use the links below for more info. on your issue. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 52
