메인 콘텐츠로 스킵하기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4730 질문 전체 보기
Why is phone coming up with the swipe to power off not charging
iPhone 6 displaying swipe to turn off /power off randomly while phone is not under charge. While under charge, phone behaves "normal"... Thank you in advance for your responses.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
2개의 답변
가장 유용한 답변
Sounds strange.
Could be that your software is not working very well. You could try a reset of all settings or restoring the unit as new to test.
Furthermore check the power button is not sticky or held down slightly. If it is use an alcoholic wipe to loosen it up.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
^^ Those are all very good suggestions. Could very likely be the button itself. Might try a toothbrush does in rubbing alcohol for that.
Go into settings and see if there is an iOS update available. iPhones are becoming increasingly more glitchy these days. Updates typically show up with a badge notification, but not always.
Also try a "simple" or "soft" reset. It's a surprisingly little known technique one had to know back in the iPod days that will reset your device without erasing everything.
Hold down the Home-App Switcher-Siri-Accessibility ·BUTTON· + Power ·BUTTON· at the same time and hold them down for 10-15 seconds. This works when an iPhone/freezes and the power button alone won't work.
Good luck. If that doesn't work try Apple customer support. Despite being more than sick of Apple, I must admit they have excellent customer support.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
jfroaddog 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 32
