주요 콘텐츠로 건너뛰기
1.4GHz 또는 1.6GHz 프로세서, 64GB 또는 128GB SSD.
162 질문 전체 보기
Backlight Ribbon Cable Installation
Hello everyone, I'm just wondering if there is any specific trick to putting the ribbon cable for the back light back in?
I snapped my last one being too tough with it, ordered a new back light which I have put onto the Macbook, now the problem is I don't want to snap the cable again but it seems to need to go a way that is not natural for the cable?
Is there a trick to it or can anyone show me a picture/video of how to do it?
Thanks,
Jamie
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You just have to use bent tweezers, and carefully push it into the connector on the PCB (with the latch lifted), there is no trick to it. You just have to position the PCB at a good angle, and the cable will slide in easily. Make sure you fit the cable the right way, so you can see the white line on the cable line up with the connector as you push it in. Just don't force it, since you can rip the cable, or slip and scratch the backlight.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Jamie Watson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 170
