Horizontal pixel lines failure for with screen replacement.
Hi people,
I have came across this problem a couple of times already. Thing is, I get a brand new replacement screen (from different sellers), fit the new screen without any problem, and when turning the phone on, this fault appears at the bottom pixel lines of the new screen. See pictures attached:
https://drive.google.com/file/d/0BzpvsfJ...
I have got some of the screens changed by the sellers, both of us thinking it was a factory issue. I tested the last screen I had recieved though, and it worked well for the first connection. After the - careful - assembly of the phone, these lines appeared. Of course, no hard reset would help.
I have replaced screens on a couple of iphone 5s models without any problems. It seems like this particular phone so to say 'ruins' the perfect, brand new screens during the installment.
I have got a new screen now, waiting to be installed, and I would like to ask you what would be those things in your opinion I should handle with special care. I can assume it's the ribbon cable bending in a bad way, or being pressurised by some other components.. or maybe the LCD display's socket on the motherboard is worn out that much that it damages the connector. I have no magnifier, so I don't see.
I have also tested the phone with another screen I use for test (it has broken glass, so this is its only purpose now), and it worked well, no pixel issue.
Could you give me some hints, please?
Thank you.
Tamas
좋은 질문 입니까?
